Originally Posted by
nine o nine
From my 4 stroke motorcycle racing days...smoothing the radii in the intake and exhaust manifolds and heads makes for a smoother mixture flow but may or may not change performance. What will help however is TUNING. Unless one could experiment with different length headers there might not be any performance gain available. As we've found out however,
the Moki radials don't need MORE performance. Out of the box they'll pull rediculously pitched props. Mitch
Yes, well I don't need more power either, just want to see if it can give more power. And if it is now consuming more fuel, one would expect it would give more power. I suppose it could unload even bigger pitched props now in the air. Moreover, I felt that the lower cylinder at 5 O'clock is not cutting out the way it used to, meaning it is not so sensitive to the needle settings as before. Perhaps it gets better mixture there as well.
