internal push rods for both elv and rud
Hi
guess this is a bit of an old thread but I placed both push rods in the fuse. Elevator as stock exit but as far to the side opposite the rudder as possible. Music wire from the rudder hinge line down through the fuse to tail wheel. O wire wrapped a lever on the music wire inside the fuse for the control rod to work on. this little lever must have the same length as the horn on the servo to prevent binding. the flex rod is for the antennae.
