RCU Forums - View Single Post - Troubles are not over..
Old 01-05-2014 | 03:32 AM
Tanque's Avatar
Tanque
I was going to bet it was a track pin also. I had a trick pin jam on the side of one of my 1/10 tanks ( JagdPanther ) when I was running
in the lowest gear at nearly 3/4 throttle. The result was all the engaged gear teeth from a module 1 steel gear being sheered ( ?) off
and a 12mm steel shaft bent. Quite annoying.
Jerry
