Originally Posted by
mick15
That's the point, if you have a very powerful engine, loading it up with pitch makes the model fly faster, to the point where they are flying too fast and do not look scale so, you load the engine with either diameter or more blades.
Fine pitch is like a low gear the plane will climb better accelerate better and so on, that's why planes take off in fine pitch then go to course for cruising speed.
m
with all do respect, I can't agree. speed is the result of pitch AND rpm. A 2-stroke turning the same diameter prop with far less pitch at far more rpm can be going the same relative speed as a 4-stroke with twice the pitch yet half the rpms, but both engines will be their power zone. have you ever heard of a constant speed prop? It is all about pitch.
