Originally Posted by
ram3500-RCU
that is over 155 mph. the air frame is only rated for 125. other planes may benefit from what you are doing, but the CARF Corsair can't handle it. The stock Moki is more than enough.
I know the CARF corsair cannot handle the speeds my plane is running at. Therefore it is good that it is not a CARF model, but a build from Don Smith plans. And for the scale appearance, it is already overpowered. I've measured over 60# of thrust with the soloprop. And the plane weights the same. So if I want to fly scale and will have to use the throttle. And now with the new heads, even more. I have been thinking of going bigger diameter, but have not seen good ones yet. 38" would be scale size, but that might be too big for the moki.
