Originally Posted by
A343
I've decided to only purchase one CANLCD and use it as a "GSU". The display is connected to the airframe with a Modular RJ11 plug. JC is using RJ12, Xicoy v.6 a RJ45 and Xicoy v.10 a servo connector. i.e. preventing myself from any mix-ups.
To further prevent any problems, I've soldered a male servo connector to the JC i/o board (special polarity, check the very comprehensive manual). Now I can connect the ASSI to the i/o board with any std female/female servo lead without giving it any x-tra consideration. (KISS)
Thomas
Thank you for the heads up Thomas. Very nice setup!
That makes a much nicer GSU display. The oiginal GSU would still need to be carried in the field box in case one wants to change some ECU parameter...
