RCU Forums - View Single Post - Gun barrel stabilization...
Old 01-09-2014 | 05:02 AM
heavyaslead's Avatar
heavyaslead
While not an exact answer to your question, I use the Tamiya gyro for the Tam Leo2.
The unit goes in the turret (same location as the gun barrel).
Servo with stick, gun stays, as the Tam T-06 detects pos stick or neg stick for elevation, not current position.
Not sure why you need two-axis gyro as vertical is the only detection needed (unless you plan on using IR tracking for turret rotation axis orienting).
Heli's need dual because of rolling, if a tank rolls you have bigger issues than orienting the gun!
