RCU Forums - View Single Post - Gun barrel stabilization...
Old 01-09-2014 | 09:38 AM
mcm308
Originally Posted by cleong
Something like that exists:
http://youtu.be/h3Sey8_ZsF8
THAT is the show right there ! I need to find out how that system operates.
Originally Posted by TheBennyB
Not sure if you'd be able to get a 2 axis gyro to work both elevation and turret at the same time. you May have to go with 2 independent gyro's. I ditched the tammy gyro in my Leo2 and
use a r/c sub pitch gyro. They're plug and play, small, and in the same ball park as the tammy gyro price wise. They also have an adjustble pot for sensitivity.
http://www.engel-modellbau.eu/catalo...oducts_id=2555
Im pretty sure the units designed for airplane flight can stabilize both axis at the same time. Aileron and rudder for example.
I might try the Hobbyking RX3 unit. Its pretty cheap and can be switched on/off via aux. Switch on the Tx.
