Originally Posted by
fw190
Nothing you need to do, it will show up on your telemetry screen as the A1 value. Same as your RSSI link value. If it was not already set you must make sure A1 voltage range is 0-13.2 under telemetry (that should have been set as the default). Range 0-0 will show 0.0
Thanks! Another question. Frsky has a new 40 amp current sensor that works with the smart port. If this is used. It is supposed to provide current, voltage, and mah used. I have been playing with C9X (I don't have a taranis) trying to figure out how to set it up but nothing looks correct. Do you know how I would set it up to work?
Later;
D.W.
