The only concern I have when mounting my four strokes inverted, is can I get the centerline of the fuel tank low enough in the fuse to line up in the correct relation to the needle valve/carb. Sometimes its possible, sometimes its not. This is where a lot of people run into problems when mounting inverted, and don't even realize it. If you had the pumped version, there would be no issue. Good flying!
