RCU Forums - View Single Post - Quadra and US Engine
Old 01-11-2014 | 08:50 AM
w8ye's Avatar
w8ye
My Feedback: (16)
Originally Posted by f16man
I have a quadra 35 with nospark all it has is a coil and a kill switch does it need a module or is it buil in to the coil, the coil has a hump on it wher the kill switch plugs in , also the crank has no cam for points but there is three screw holes to hold points plate possibly, this engine is mounted on an old byron pitts and looks like the stock mount and engine sold by byron yars ago any help would be great thanks.
This engine is likely complete. Why not see if it'll make a spark in the spark plug?
If you remove the spark plug from the cylinder and ground it to the outside of the engine with the wire attached, you should be able to easily spin the engine fast enough to make a spark?
