Originally Posted by
izzy-israel-73
I will be running a regulator for the ignition I have herd that the new ignitions on the DLE's you can run 7.4 threw them is this right?
It should tell you the voltage range on the CDI ignition module.
The 73" (gas powered) Sbach I'm putting together currently will run two separate 2 cell lipo or life batteries (ie 7.4 or 6.6 volts) through one of these:
http://www.hobbyking.com/hobbyking/s...utor_RED_.html as I chose to run twin batteries for the electronics when I have a total of anything over 5 high draw servos (that has 7 including choke and throttle), and a separate 4.8 volt NiMh for my CDI ignition as I opt to keep the individual power systems (motor and electronics) separate. Like you, I'm running high voltage digital servos that can handle that voltage directly, so a voltage step down regulator is not needed.
The beauty of that power distributor aside from being a redundancy system, is that it includes an inbuilt remote controlled CDI optical ignition kill switch, which again I like, and if a company like Redwing RC can offer these same items as well (who I feel strive for supplying quality items), on top of what I have seen others gain from them elsewhere, then I feel safe using them (
http://www.redwingrc.com/index.php?m...products_id=82)
