RCU Forums - View Single Post - Evolution 62 EFI
Old 01-11-2014 | 12:57 PM
SJN
Default Evolution 62 EFI Fuel Injection
Did you guys see the new Evolution 62 EFI
Fuel injected, and no more mixture screws to mess with.....now even the electric poeple can handle a real engine
Overview
Now there’s a Giant-Scale gas engine for those who don’t want the requirement of engine expertise. The Evolution® Engines 62GXi is a potent 62cc engine with the efficiency and convenience of an electronic fuel injection system. Simple to setup and maintain, it’s a Horizon Hobby innovation that means you never have to touch a needle-valve to enjoy starting ease, reliability and long engine life. That’s because SureFire™ Electronic Fuel Injection (EFI) technology combines finely-tuned software and sophisticated sensors so the engine gets the perfect flow of fuel no matter where or what you fly.
The Evolution Engines 62GXi is the only purposely built RC engine on the market to feature an advanced electronic fuel injection system specially made for the needs of the giant-scale model pilot. There are no needle-valves to ever worry about because the SureFire EFI™ system provides smooth, reliable operation and optimum engine transition automatically, regardless of throttle position or atmospheric conditions. Just fuel, flip and fly.
Like all Evolution engines, the 62GXi is built to exact standards with high-quality materials, plus it comes ready to run with a compact 2-cell Li-Po compatible ignition and high-quality muffler. It’s the most advanced giant-scale gas power system you won’t have to touch except to fill the gas tank.
Specifications
  • Type: 2-stroke gas/petrol airplane engine
  • Displacement: 3.75 cu. in. (61.49 cc)
  • Bore: 1.81 in (46.0mm)
  • Stroke: 1.46 in (37.0mm)
  • Cylinders: Single
  • Total Weight: 66.6 oz (1888 g)
  • Engine (Only) Weight: 53.8 oz (1525 g)
  • Muffler Weight: 8.2 oz (233 g)
  • Crankshaft Threads: 4-5mm prop bolts on 30mm diameter centers
  • Benchmark Prop: Falcon 23 x 9 @ 7300 rpm
  • Prop Range: 22 x 8 - 24 x 10
  • RPM Range: 1,000-8,000
  • Fuel: 87 octane and above, synthetic oil at 32:1 ratio
  • Muffler Type: Inverted wraparound (included)
  • Cylinder Type: Ringed
  • Carb Type: Electronic fuel injection
Features:
  • SureFire™ EFI electronic fuel injection system
  • Electronic ignition system with 7.4V Li-Po battery compatibility
  • Purpose built engine for giant-scale model aircraft
  • High-quality materials and lightweight design
  • Shares the overall dimensions and mounting pattern of other popular engines in its class
  • Common muffler mount fits a variety of available exhaust systems
  • Dual ball-bearing equipped, cantilevered crankshaft
  • Common 4-bolt propeller mounting pattern
  • Built-in crankcase support means only short (50mm) stand-offs are required
  • High-quality CM-6 spark plug included
ID:	1956485   Click image for larger version
ID:	1956486   Click image for larger version
ID:	1956487   Click image for larger version
ID:	1956488   Click image for larger version
ID:	1956489   Click image for larger version
ID:	1956490   Click image for larger version
ID:	1956491   Click image for larger version
