Aurora 9X, printing manual, Walkera QR X350 quad copter
1. I have a new Aurora 9X and was a little disgruntled when I discovered no hard copy manual. I printed out in booklet form on an HP Office Jet 8600+ which ended up as 32 pages. I then took the pages down to Office Depot and for less than $5 had the pages converted into a very readable booklet. The result is just slightly smaller than the Aurora 9 manuals. Hats off to Office Depot for doing such a nice job. I am sure Office Depot can go from CD to nice manual also.
2. My Problem I installed A Minima 6E in a Walkera QR X350 quad copter. Per the Quad manual the channels used in order Elev; Aile; Thro; Rudd; Gear; Aux1 = 1 - 6.
These are supposed to be connected to J2; J1; J3; J4; C; B; which they are according to the Channel Function page. I now need to set the levels for the two switches C=On, Mid, Off and B = On, Off. Switch handles from forward to backward. I am having trouble finding the information to accomplish this.
3 Special note on the Walkera quad. On the 6 supplied cables that connect from the Receiver to the Walkera Main Controller only one had a center wire. I measured the
main controller And the voltage was bussed across all 6 channels and the power input ( As is common practice. ) I changed the ch 6 ( Aux1 ) cable to a 3 wire so their was
a redundant voltage connection to the receiver even though the current drain was low due to no servos.
