RE: G.P. Pitts engine angle?
The right thrust built into the firewall of the Pitts is intentional. Without it, the plane would be very hard to trim out for aerobatics.
I'm flying mine with a Brisson 3.2 gas engine, and when I power up for take off I still have to input a lot of right rudder to offset the torque.
The size of this plane dictates that a larger engine be used than a lot of people may be used to. Great Planes actually did us a favor by building in a SMALL amount of right thrust (about 1/4"). Without it, we would all be adding washers under one side of the engine mount to correct a left yawing tendency. It also helps the plane roll fairly equally both left and right.
Don't change a thing. Just center your engine in the cowl and everything will work out great. It's a good flying bipe. Keep the speed up on final and don't cut the throttle to idle until landing is assured. Just like the full scale.
Silversurfer
