You are using different nose gear, but if you chose to do a 2 part nose door check the split lengths. Std it comes out with the front section a bit long for the Behotec leg and it catches the tyre. Your leg might be shorter still so check the door length with the nose strut compressed.
Balance point is different than the Classic. Flaps will require down elevator mixed in too.
Dw
