Originally Posted by
PaulD
There is heavier wire available, however, usually the insulation is too big to fit into the connector housings.
Paul,
The way I am doing it is to just use the heavy wire for the bus (like a bus bar), then I am soldering on standard 22 gauge servo leads along the length of it where a servo needs to connect. Each one of the leads that is soldered onto the bus wires will have a single standard servo connector on the end of it and one servo will plug into each one (except at the wing connection where the flap and aileron servo will be Y'ed together and plug into one lead).
I will take some pictures when I get around to assembling it.
