The advantage of the XBus is that it can control up to four servos on each channel. So even the XG8 with the XBus update should handle most Giant Scale requirements. One disadvantage of a serial bus that I haven’t seen discussed is it that introduces the possibility of a single point failure where none hadn’t existed before. A failure in the wing hub could knock out every servo in the wing.
Allan
