RCU Forums - View Single Post - Evolution 62 EFI
Old 01-17-2014 | 01:02 PM
  #45
chuckk2
Originally Posted by Cyberwolf
If an O-2 Sensor is not needed, why do each and every car built in today's world have at least one and some times as many as three?
Don't confuse what is needed for an engine to run with what is required by the EPA emission standards.
Generally, a throttle position sensor and ignition timing control/sensor are the minimum. Run well? not necessarily.
Remember that current automobile systems often do not have a mechanical throttle valve connected to the accelerator pedal. They rely on "the computer" to set
fuel, timing, and air flow, based upon the pedal position and other measurable operational conditions.
