RCU Forums - View Single Post - New! - Aerofly RC 7
Old 01-18-2014 | 02:19 PM
Flakpak
I'm not impressed with the back-up, period!
As a user of Aerofly Professional De-Lux I had a comprehensive instruction manual, and had no problems finding my way around the settings, However there apparently is no manual for AeroflyRC7, and although most of the settings are self explanatory I am having problems setting up my controller, and am wondering whether I installed the download correctly.
There were two links given online after I paid for the download, and I might have chosen the wrong one. Wondering if I should attempt to uninstall the programme completely and download it again I raised this issue with Ikarus on 9th January, and forwarded my ".tml" and "DxDiag.text" files when requested, and am waiting for a reply.
Until today the programme has been fine except that, on every start-up, it does not recognise my controller (Spectrum DX7) and I have to scan for it and sometimes recalibrate and reconfigure it.
Today I tried to set up the rate switches and found it impossible. I don't know if I can use the rate switches on my transmitter, or if I can only use the Dual Rate Switch in "Advanced Channel Set-up". When I try to allocate a transmitter switch to the "D -R" switch, it is not accepted.
I have ended up with ailerons which only work very slowly and remain deflected when the transmitter stick is centred!
