TW,
Not sure if your refering to how to get it to stick or how to do the scallops.
To get it to stick I'd use trim Monokote trim solvent. They designed it for exactly what you want to do.
I had conversations with people about the Windex method. Most believe that Windex glues the trim to the Monokote. I don't see how. I think it's surface tension from the soap in the Windex that keeps it down by removing any trapped air.
Trim Solvent bonds Monokote to Monokote. It melts the glue without have to use an iron. You also half plenty of working time to aline it to get it straight.
As far as the Scallops you'll have to figure out and mark equal spacings for the scallops across the wing. Next I'd look for a can or cup and use that as a guide for the scallops.
Regards,
Bryan
