Hi Pete,
As per your post below, does this mean the engine will stop if the LiPo reaches 7.4V ?
Is this really true, even though this is only 3.7V per cell for a 2 cell LiPo, and is roughly only 50% of the usable capacity depending on discharge rate ??
I would much rather risk damaging my ignition battery by accidently taking it down to 6.0V rather than have the engine cut at what may be a very inappropriate moment.
Is there a low voltage warning such as momentary throttle cut blips or pulses to warn the user the are close to the cutoff ?
Jag
Originally Posted by
Pete Bergstrom
It does need a 2S LiPo because the minimum voltage for the overall system is 7.4v.
Pete
