RCU Forums - View Single Post - RCGF 26cc beam mount engine
Old 01-23-2014 | 08:59 AM
  #41
dirtybird
Originally Posted by mach2
I'm a little confused about one thing. Did you buy the ring and receive the note from Frank Bowman or Joe? I have seen pictures of some "flashing" on the internals on some engines. Especially on the reed cage. I've had my DLE20 apart for repair and inspection. I did not see any areas with flashing that needed to be cleaned up. On the DLE20, the reed cage is a polymer and had no areas that needed to be cleaned up. I love that little engine. I think I'm going to try a Bowman ring in it, as well as possibly testing out a "velocity stack", just to see if the engine runs any smoother. I'm not sure how I can really tell, because it runs so well already. But I like performance upgrades! I think it comes from me always tinkering on my cars (superchargers, cams, rocker arms, etc...).
As for NGH engines, I'm not a fan of the carb location on them. I've also read a lot of negative things about that style carb configuration. Seems like they need some modifications to make them run as they should...
Oh, and just fyi...I realized I will be on duty friday and saturday, so I will not be able to get my hands on the engine until I get home sunday...
Jeremy
The note I received was from Bowman.
I like the carb position on the NGH. Its a lot easier to prime the engine and hook up the throttle control. And there is no reeds to worry about.
What issues have you heard about the NGH? Mine runs just fine
