This post has less to do with WD40 and more to do with Saito engines. I am about o build a Balsa USA Nieuport 17 1/6 scale kit. The kit calls for a .50 size 4 stroke. I would very much like to use a Saito FA-56 or a Saito FA-62 as power for this airplane. Can some one tell me if either or both of these engines will fit under the cowling? The Saito site does not give the physical deminsions or the power rating for either of these engines.
Thank you,
Cyco
The Sai 56 or 62 is a perfect substitue for the previous 50 size engines. The dimensions and specs can be found on page 17 of the manual found here:
http://www.horizonhobby.com/pdf/SAIT...der_Manual.pdf
Pete
