RCU Forums - View Single Post - Behotec e-Tract user manual.
Old 01-23-2014 | 11:32 PM
2walla
My Feedback: (10)
Originally Posted by bluelevel
I understood that it is recommended to connect the brake & steering input with only the signal and the negative wire, otherwise it would destroy the controller. But what about the actual signal input, this comes with a cable that has all 3 wires connected to it?!
Thomas
I dont see how this would work? The gear controller provides power to the steering servo? Or do you need to make up some sort of y harness for power? Doesn't make sense.. I have read everything i can find on these and see no mention of anything about not running receiver power in the servo inputs.
As far as a power switch, if you dont have an on off switch to the battery it will probably run the pack dead and ruin it within a few days.
What are you putting them in? I am looking ordering a set for a carf tutor.
