[QUOTE=kahloq;11718982]Deadstick....I should warn you about using that red valve with no needles....
Yes it will work and that's what I ended up trying on the me-110 after the failure with deploying the gear.
The problem stems from the fact that the needle hole is now completely open and if the servo operating the valve doesn't close the valve all the way 100% in either direction, the valve just dumps out all your air.
What would happen if I took the needless and jam nuts out of my ROBART red valve and replaced them with an inch of air tubing and the wheel collar set up mentioned in an earlier post? Would that be a remedy for the course adjustment on the needle valves or not? IT won't solve the gear failure problem due to a leak but it might help the fine adjustment with the rate at witch the gears moves.
