Originally Posted by
rcworld2000
ok here it is i picked up a used plane from a guy he it has a retract servo he said it wasnt working... so i got it all set up with my new futaba 8fg radio. i got all the servos going.
so i figured i would try a flip the the switch for the retract servo and nothing happend then all of a sudden the wheels came put. then i started to get smoke from the wing and so i pulled all the wires and removed the retract servo the bottom of the servo was melted? could this have been a bad setting on my radio or just a bad servo?
I'm just curious, what size plane have you got? The reason I'm asking is the 1/2" of travel for the retract to fully cycle you mentioned, every 40 - 60 size mechanical retract I've delt with required 23 to 25 mm of travel. I remember reading an article here on RCU that described the proper way to set up mechanical retracts, I wished I had seen it when I set up my first set of retracts in 1993, I would probably have more hair now.
