My thoughts are the same. Poor craftmanship. I have found out that some engines are missing a front seal. Will take it apart & reseal with sealer or new gaskets. Will post my results
Well I took the pulse line off from the carb side, blew into the line after I sprayed soap liq. all around gaskets, front seal & carb.Could not find any leaks. Changed the carb, no difference. Next thing I will contact Milton @ ecexel & see what his thoughts are.
