Blainer48
I mounted my Go-Pro to my Shok-Jet by gluing a plywood plate under the fuselage top, behind the hatch and in front of the wing. Then bolted one of the go-pro mounts into 4x40 blind nuts in the ply plate. I used flat head counter sunk screws. Worked fine and the shok makes a fine camera mount. Did not effect the flying characteristics at all. I had to use one of the mount extensions to get the camera above the canopy. Works great facing forward or backwards.
Give it a try.
Shepp
