Thrust tube cut ....
Trying to keep the distance of 20mm-30mm from turbine exhaust to thrust tube lip i need to move the tube rearwards and it protrudes about 15mm from the aircraft nozzle.
I cannot move the engine forward and it seems that the only solution is to cut the thrust tube ends.
will this affect the thrust or create any other problems.its an f18 tube.
Nicos
