It is not easy getting it perfect so I just go by feel and if it is close then that is best that I can do. You can make templets and jigs if you want perfection. I find doing the skins first then adding the LE helps. I also used a pre shaped LE so it was easy to get it uniformed, but I'm not doing it the way the kit wants you to!
TB
