RCU Forums - View Single Post - Thrust tube cut ....
Old 01-26-2014 | 09:43 PM
lookilook's Avatar
lookilook
Hi Rcpete and Dr Honda,I was also thinking of cutting the front end of the pipe but because is a dual exhaust pipe i thought is better to cut down both the rear ends as cutting the front part will reduce the distance from the lip to where the tube splits into two exhausts and might have an effect.I am not sure if it will affect it at all hence i would like to hear from experienced people like you guys and then proceed.
