Hi Skywarrior;
Nice set up.
I need to mention, but I do not see your overboard fuel
vent line. Maybe it is just not in the PIC.
Your final Main tanks should be vented to overboard when full.
Please explain your set up.
I am just curious.
You should vent your single tank to your two main tanks
and your main tanks vent line to overboard with a Tee.
I will draw an example for you later.
Don't get me wrong I am just curious and not telling you what to do.
Skywarrior, I don't think you should worry about the offset horn for the flaps.
They are well placed and will work fine in flight. Your ball link should be placed only on the
outboard side for that is the best side to get the most movement out of the flaps.
But if you feel comfortable with your set up then keep it
I have my own set up also.
