RCU Forums - View Single Post - Kingtech 180G Tail pipe diameter?
Old 01-27-2014 | 08:31 PM
marquisvns's Avatar
marquisvns
Hi Craig, the recommended distance between the tail cone and pipe is all in the manual, which is about 20 to 30mm, as with the diameter, it has everything to do with the length and its taper, please contact the maker of the pipe for its rated thrust. Otherwise, if you need a replacement pipe made, please contact Tam at tamjets.com
Barry
