RE: How do you install a spinner with spinner nut?
It depends. If you have the room and/or you need nose weight use them both. I personally use only the adapter nut. But make sure you use both washers.
Also dont over tighten the screw that holds the spinner on. It's easy to bow out the spinner around the prop clearence slots. Later David
