Nothing much to report except I'm building the upper wing. Next bit of head scratching will be the upper mount. I'd like to use wing bolts instead of that wire, so I've been looking at the build info from peternj and will work something like his mounting into my build.
Pretty frustrated also when I checked the incidence. Everything was right on except one wing tip. Somehow I got a bit of a twist. It had to have been when I put the last piece of leading edge sheeting on. I must have pressed down just a bit to hard and didn't catch it until it was to late. So, some research shows I should be able to mist it and weight it down and get it out.
I'll be picking up the motor and ESC Friday, so I can get that mounted and the rest of the fuse done.
More to come.
