Originally Posted by
stivvy
Hi Gary,
Nice tail door system.
Did you find that the system you used previously (with the ball links/rigid connections to the tail gear) didn't work too well, as I fancied giving that a go). - See post 682 for those who haven't seen the earlier version
Your new method looks a little more complex to install/set up - plus it looks like you have no chance of adjustment once the pull-pull wires are crimped ??
Keep posting !!
Regards
Steve D
Hello Steve. Actually, it is just the opposite. The new system is very easy to install and adjust. MUCH easier than the one with ball links. I did NOT need to learn a new language to install this one. :-)
As for the cables, I had planned to use a small spring in the system so I could put some tension on the cable to insure it stays tight, but I deemed this unnecessary. I have a couple more videos to post but am having a little trouble with them. I have uploaded one 3 times and it keeps rejecting it.
More on this subject to come.
