Originally Posted by
52larry52
TomCrump, thanks for the link to the full scale Rascal build. It truly is "very interesting". From time to time I will check in on his progress. Someone on that thread posed the question of whether our Rascal models will be true "scale models" when this man's full scale build is completed and I say definitively YES ! Many a full scale aircraft started with a model used in the wind tunnel going all the way back to the Wright Bros. So, YES if he finishes and flys the full scale Rascal, ours' are then "scale models". What say you?
The Rascal will be a "fun scale" model as the full sized one has had several changes such as fuselage length. It is not simply a blown up paln.
