RCU Forums - View Single Post - Unequal elevator halves
Old 01-31-2014 | 06:19 AM
  #31
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Originally Posted by rgburrill
Agreed. It does not appear that anything is wrong with the parts - just the installation! Turn the clevis down on one to align the trailing edges.
Your not looking at the whole picture here. He said that the LE of the counterbalances are lining up with the LE of the stab and that leaves him with a mis alignment at the elevator root. Simply moving the clevis to line up the elevators at the root is not going to fix anything. The elevator/s have a twist. Look at the construction used, it should be a fairly easy solution to twist the elevator/s the opposite direction and re-shrink the covering to straiten them out as the twist was most likely introduced during the covering process in the first place.
