RCU Forums - View Single Post - Unequal elevator halves
Old 01-31-2014 | 09:27 AM
  #33
opjose's Avatar
opjose
Originally Posted by ameyam
Guys, just hold on.
Opjose, curt as it may seem, people learn over time. I wish you would pick that up
Some tend to overthink the small things causing them to miss the important ones and that tendancy does not disappear.
Unless the elevators are asymetrical (e.g. warbird, etc. ), a left hand elevator, recovered as a right hand elevator is for all intents and purposes a right hand elevator, particularly on a 3D plane such as yours.
First remove the elevators and try to eliminate any warping.
If you succeed re-install and align their TRAILING EDGES at center and also at both extremes.
If you cannot remove all of the warping, adjust the trailing edges at centers and extremes, then slightly re-align them so that you get the "average" position of the elevator being the same, so the effect on the plane is about equal on both halves. At best this is only an approximation.
On a 3D plane you will very much notice the warping in flight during tight loops, high alpha, and stall turns.
