RCU Forums - View Single Post - A Ringmaster Bi-Plane
Old 01-31-2014 | 12:34 PM
  #113
flyingagin's Avatar
flyingagin
More work on the struts. I am just guessing and fumbling around a bit. Sort of making it up as I go.
I cut some strips of 1/8" balsa about 3/8". Tried to sand a bevel and in about one minute said forget this BS. So just sheaved a bevel by hand with an Xacto, then a few passes with sand paper. Glued then together so as to have a inset ==< sort of shape, a V notch is the best I can describe it.
I glued this to the carbon struts. Then some carving with a SHARP Xacto, some sanding. Now I have the first one covered in spackling and drying. Then another sanding and hopefully it is good enough for the aluminum tape.
I am really anxious to get to that point and see how it looks.
I am sure hoping this works.
Ken
ID:	1964155   Click image for larger version
ID:	1964159   Click image for larger version
ID:	1964160   Click image for larger version
ID:	1964162   Click image for larger version
ID:	1964163   Click image for larger version
ID:	1964164   Click image for larger version
