RCU Forums - View Single Post - converting air to electric retracts.
Old 01-31-2014 | 06:31 PM
  #35
mustang493
here you go Mike i've cleared your errors which were mainly simple typos or use of caps when it should be lower case. good effort. i've not examined it to see if it will work but try it and see what happens.
// Arduino uno with R3 motor shield // RC retract under-carriage sequencing
// door actuators and under-carriage retract actuators
#define midlimit 1700
int Abrake=8; // brake signal for motor A doors actuators
int Bbrake=9; // brake signal for motor B retract actuators
int motorspdA=11; // PWM speed signal for motor A doors actuator
int motorspdB=3; // PWM speed signal for motor B retract actuators
int ch5; // Receiver retract channel
int motorA=12; // motor initiate door actuators
int motorB=13; // motor initiate retract actuators
int sensorPinA= A0; // select the input pin for the current door actuators
int sensorPinB= A1; // select the input pin for the current retract actuators
int switchpin =2;
int sensorValueA =0; // variable to store the value coming from the sensor
int sensorValueB =0; // variable to store the value coming from the sensor
void setup() {
pinMode (6, INPUT);
pinMode (12,OUTPUT); // motor A enable and direction HIGH or LOW
pinMode (13,OUTPUT); // motor B enable and direction HIGH or LOW
pinMode (8, OUTPUT); // brake motor A doors
pinMode (9, OUTPUT); // brake motor B retracts
pinMode (switchpin, OUTPUT);
void loop () {
int limitA = 550; // this is the current limit for motor A doors
int limitB = 300; // this is the current limit for motor B retracts
sensorValueA = analogRead(sensorPinA); //this reads the value of current for motorA and sets the variable sensorValueA , doors
sensorValueB = analogRead(sensorPinB); //this reads the value of current for motorB and sets the variable sensor valueB , retracts
int iA =0; // this creates and sets a variable named iA which we will use to make sure the motors stop once they reach overcurrent condition
int iB = 0; // this creates and sets a variable named iB which we will use to make sure the motors stop once they reach overcurrent condition
ch5 = pulseIn(6, HIGH);
if(ch5 < midlimit) {
digitalWrite(switchpin, HIGH);
else {
digitalWrite(switchpin, LOW);
int updwn = digitalRead(switchpin); // this sets the value of the variable updwn which is read from transmitter switch
int updwn2 = digitalRead(switchpin); // this sets the value of the variable updwn which is read from transmitter switch
while (updwn == updwn2) { // the while loop here knows the current state of the switch updwn. During the while loop it will continually check
//the state of the switch by setting updwn2 therefore once the state of the switch changes it will exit the while loop
//if (updwn==1 && sensorValueB < limitB && iB==0)
if (updwn==updwn2 && sensorValueA < limitA && iA ==0)
analogWrite (motorspdA,255);
//digitalWrite (A,HIGH);
digitalWrite(Bbrake,LOW);
else if (updwn ==0 && sensorValueA < limitA && iA ==iA ==0)
digitalWrite (motorA,LOW);
digitalWrite (Abrake,LOW);
else
analogWrite ( motorspdA ,0);
digitalWrite (Bbrake,LOW);
iA++;
delay(300);
if (updwn ==1 && sensorValueB < limitB && iB ==0)
analogWrite (motorspdB,255);
digitalWrite (motorB,HIGH);
else if (updwn ==0 && sensorValueB < limitB && iB ==0)
digitalWrite (motorB,LOW);
else
analogWrite (motorspdB,0);
iB++;
delay(200);
sensorValueB =analogRead(sensorPinB);
int ch5 = pulseIn(6,HIGH);
if (ch5 < midlimit)
digitalWrite(switchpin,HIGH);
else
delay(100);
