Originally Posted by
nosram
If the release agent isn't completely removed from the fiberglass component then the paint will not stick.
Even if the release agent is washed off, the surface still needs to be sanded. An abrasive pot scrubber pad may be good enough. This is the labor intensive part that is very tempting to skip. If you do a re-spray, don't skimp on surface prep.
