Originally Posted by
Countryboy
Try wedging something under the bolt head or use locking pliers to pull on the bolt in order to try seating the blind nut best as possible. Now heat the bolt head with a soldering iron to soften the Loctite and promptly try to remove the bolt.
I agree with Countryboy here.... I've had a similar issue with an Edge 540 I had.... I tried to carefully force the bolt back out, but then the blind nut came loose. So I had to then force it out and glue the entire wing on permanently.
So as Countryboy said, I'd find something to fill the gap. Maybe take 2 small blocks of wood and cut semicircles (bolt circumference) in the wood, that way you are able to place a block either side of the nut, forming 1 big block. Then hysol the lot together.
