RCU Forums - View Single Post - Help with stripped Hex Bolt
Old 02-03-2014 | 03:42 AM
gene6029's Avatar
gene6029
Another way to apply heat to the bolt is with a soldering iron held on the bolt head. It applies the heat directly where you need it. An easy out with the tip ground flat to fit inside the bolt head will allmost definately break it loose......Good luck...Gene
