RCU Forums - View Single Post - converting air to electric retracts.
Old 02-04-2014 | 12:46 PM
  #40
freelander-rider
hi Mustang,
Thanks again the code verifies, haven't loaded it yet I am setting up a board jig with the retracts and door actuators in place, so I can check the system will work as intended.
Have wired up the motor actuators, doors output A and retracts output B, lipo 2s 7.4 battery on vin and grd on shield, and nicad battery plugged in receiver, now I see from your U tube wiring the shield
I need to fit the plug, to the receiver retract channel, signal - power - and grd, and then attach wires, signal to pin 6 and black ground pin, now is the black ground wire connected to grd which says power or next to, which states grd and 5volts, also on the vidio, I can see the white signal wire to pin 6 and the black wire to ground, but I cant see a red power wire connected,( Center pin on receiver retract channel) does this need to be connected to a vin on the shield.
Mike
