RCU Forums - View Single Post - Phoenix 5 out soon!
Old 02-06-2014 | 10:52 AM
opjose's Avatar
opjose
Originally Posted by verendrye
I have been trying to get a three position flap switch to work in Phoenix. What happens is that I either get full up or full down with no intermediate displacement. If the range is precisely set , the flaps flutter between full up and full down. I am using a Dx7 with the flap switch. I have also tried using a Dx9 assigning the rotary knob, with the same results. The Horizon help guy insists that I have the range set improperly. I tested the flap by setting up a 6 channel receiver with servos. It worked exactly as expected. The same transmitter does produce 1/2 flap deflection in FS-1 as well. Any suggestions.
thanks
Phoenix treats inputs as "buttons" or "axis".
If the former, then Phoenix treats the input as a toggle and you get what you describe.
If the latter, then you get a range of movement, e.g. via a knob.
