RCU Forums - View Single Post - Identify this engine and problem with starting
Old 02-08-2014 | 04:01 PM
Indiomike's Avatar
Indiomike
Hi w8ye. I tried to upload one at a time and all four. No luck. I've tried to drag the photos into the lower box where it says to drag but the photos snap back as if on a rubber band. I've tried to load them by file number and when I hit basic upload it tells me the upload failed. However, it doesn't say why the upload failed. I tried the "done" button after choosing the files and it then tells me to drag them into the lower box which I already tried.
This is so frustrating. I've tried several different ways to get the pictures into a post but nothing works. I'm going to give up unless someone suggests a way I haven't tried yet. I run a IMac computer. The photos loaded into iPhoto no problem but for some reason I can't figure out it won't let me attach the photos to a post. I may have a setting somewhere that is wrong. Following the RCU instructions to upload is no problem. I suspect the problem is in iPhoto.
Mike
