RCU Forums - View Single Post - Construction techniques 1970s and now
Old 02-08-2014 | 10:34 PM
bigtim
My Feedback: (13)
the nice thing about CA is the instant bonding you get when the joints are tight speeds up the building time for sure.
in many cases I like to use Tite Bond because of the lack of odor and that it sands easier, one of my club members who happens to be a great builder thins his TB down just a bit with water and applies the glue with a acid brush to the contact points its about comfort and situations,when gluing sheeting together I always use Tite Bond for that reason of being sandable CA just turns the wood to stone.
CA is great I like to use a applicator tip when using thin CA for adhesive control its nice to just set up some ribs and hit them quickly and your wing or fuse framing is done in no time,I also use allot of Med.thickness as well for higher required strength areas.
