RCU Forums - View Single Post - Tornado EPX PRO
Thread: Tornado EPX PRO
Old 02-12-2014 | 12:00 PM
ninnimuggins
Originally Posted by nitrosportsandrunner
I think you can get standard 26mm touring car tires (as long as the offset is right to fit)
these will be shorter, and thus reduce your top speed and you will have to run a larger pinion gear to compensate.
But standard touring car wheels will give you many onroad-type tire choices.
or you can try this kinda setup: http://www.youtube.com/watch?v=7rowHZJtF1A
Right nitro, but nobody seams to know the offset. I have all other dimensions of the stock tires except the offset. Also does anyone know the range of outer diameter that can be run on these cars. I know to big and to small is a strain on the motor, am I right? I know the 2.2 is standard but what is the range. Anyone?
